Corona Discharge from 230kV Disconnect Switch
A new 230kV vertical mounted disconnect switch was recently commissioned in a substation and we noticed that significant audible buzzing was coming from the terminals (more than you would normally expect).  I am trying to determine the source of the corona discharge and how to mitigate to a more reasonable level.  We are using single 1590 AAC single conductor for each of the terminations.
Any thoughts as to the potential sources and/or mitigation strategies?
RE: Corona Discharge from 230kV Disconnect Switch
You might want to attach a picture of the installation.
You could buy/rent an ultrasonic camera to pinpoint the area involved.
You could use a corona camera available in the market now a days find the weakest point and then rectify.
Don't you use anti-corona rings on your terminals? You can Google it.
