Pls Cadd- Sag and Tension
Hi mates,
I´m trying to handle Plscadd lite with a simple example, but many doubts arise to me.
I would like to simulate double circuit line (#rail) and two ground wires (3 NO. 6 ALUMOWELD) in 300 meters of span.
I have to define weather case and tension for #rail and WC/Tension for ground wire. The tension of #rail and ground wire should be different.
How can I calculate structure loads if i can´t define different weather case for #rail and ground wire.
Thank you
