SHEET METAL - NX7.5
SHEET METAL - NX7.5
I want to create the part (Bracket) attached.
It seems that it can not be created using Sheet Metal features, but I'd like to get your opinion......
Thanks!
Thanks!
RE: SHEET METAL - NX7.5
Thank you...
Using NX 8 and TC8.3
Can you send the NX prt file?
I can't see in your picture the other side of the part......
my solution doesn't give you the same result like the part you have posted.
This part can be created in modeling and use the following tools if you want the right flat-pattern ('MetaForm' or 'Analize Formability'), each tools need a special license or you can create this part with the 'Aerospace Sheet Metal' application.
Thank you...
Edit -> Feature -> Playback...
...to review the construction steps one at a time.
Note that your original part is still there, just Hidden.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Thank you...
I have to confess you that I tried to accomplish this assignment using just "clean" Sheet Metal futures, without cutting/trimming.
You model inspired me to make it even better (I guess.....).
Please, see the attachemnt and feel free to coment my last updates.
Thanks also to Cubalibre00 for considerating my thread.
John R. Baker, P.E.
Industry Sector
Cypress, CA
