Make bush joint in Adams view
i have to add a bushing joint like the one in the attached pic. i am using adams view .. and how i define this type of bushing in there .. also what type of bushing joint is this (i mean name) so i can search for suppliers for this type of bush for properties like stiffness etc ..
RE: Make bush joint in Adams view
Typical suppliers are freudenberg, boge, peradin
If you are only interested in the linear behaviour then a Field will allow you to enter stiffnesses in 6 directions. I don't know how to do non linear bushes in VIEW, presumably MSC support can tell you if the Help doesn't.
Cheers
Greg Locock
