Circuit Breaker Test Sets
Can anyone suggest a high amperage(2000 amps max)tester? Used primarily for single phase reclosers, three phase reclosers and sectionalizers? Appreciate your time
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
Circuit Breaker Test SetsCircuit Breaker Test Sets(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: Circuit Breaker Test Sets
I work at a utility in Colombia and we have a tester AVO MULTIAMP OCR-8015-C
http://www.phenixtech.com
From a 120 V source you are correct ~1600A. @ 240V you get the full 2000A from the booster - the currents are time limited and self protected (will shut itself off). For field applications, I've worked with folks that set up 240V in service trucks using 2 UPS units in series - it worked very well.
The CPC will work well with low impedance devices, such as vacuum reclosers, switches, etc. For older hydrolic units, the impedance is too high. It will also test CT's, contact resistance, can do secondary tests on the controller, etc.
To the OP - where do you plan on using the set -in the field or in the shop?
