Determining Steam Generator Capcity
we have a steam generator (>30 year old) for which I need to determin the capacity in order to verify the PSV sizes and check its relief capacity for the existing steam generator for reduced rating (PSV set pressure) conditions (de-rating is required due to reduced tube thickness found in recent inspection).
I only have the data for the heat tranfer surfaces for the Economiser and Radiant section. There is no capacity written in the manufacturer data book. The boiler is currently under shut down due to missing regulatory compliance (PSV de-rating) and historical data is of no use as the tubes were cleaned with extensive pigging.
how do I find the capacity of steam generator (I am asking for detail sample calculation or steps)? I guess its not simple heat transfer in a heat exchanger.
RE: Determining Steam Generator Capcity
One thing you will have to do is calculate a decent estimate of your square footage which is as simple as counting your tubes and measuring lengths. Don't count surface like drum or header surfaces even if they do contribute to the steam generation.
BTW, what type of boiler is it? Straight tube, bent tube, fire tube, water tube?
rmw
I already have the surface area for the radiant and convection section. what could be the next step to calculate?
I am trying to understand the control exactly, there were modifications and don't know whether the drawing I have is reflecting the control.
any idea on how much efficiency for OTSG can be considered. I have burner capacity and also got the "Steam" book, I can calculate amount of steam generated from heat input considering the available heat transfer area of convection and radiant section. thanks
I assume that you have no particular experience in boiler performance calculations. Although this assumption may be incorrect.
I first reaction is whether you should be proceeding in the manner described above.
Best regards,
athomas236
