Emulsion Maufacturing for Heat Sensitve Compounds
I have formulated an oil in water emulsion by the fusion method. But now I want to add a heat sensitive compound to the internal oil phase. Can anyone recommend a method for incorporation of the compound in the internal oil phase, without changing my formulation ? Cold processing of the excipients does not actually work
Thank you
