HDPE pipe Supports
HDPE pipe Supports
Dear Sirs,
What are type of HDPE pipes supports?(Clamp with rubber or ...???)
Is there any guide book for HDPE pipe supporting?
I want to know all things about HDPE supporting such as pipe span, location of supports and standard drawing of HDPE supports.
RE: HDPE pipe Supports
See:
http:/
If it not clear, then call some mfg.
I hope this helps
"Sharing knowledge is the way to immortality"
His Holiness the Dalai Lama.
http://waterhammer.hopout.com.au/
What would you be doing, if you knew that you could not fail?
If you must use it above gorund then minimu 120 degree supports spaced to suit temperature conditions. Major difficulty is thermal expansion being some 20 times that of steel. When the pipe moves it can lock up onsupports and the pipe will be damaged. pipe will not remain circular even at moderate temperatures (30C plus). All this depends upon the standard ration OD/wall thickness (SDR).
Designing in PE is often more difficult than for steel.
"Support" (IMO) means above the ground, unless stated otherwise.
Actually i think it's called "duck tape"
