Removing concrete from galvanized threaded bolts
Please would appreciate if anyone there know of how best to go about removing concrete that have 'glued' to threaded bars. The bars are galvanized and so i do not want to damage the coatings in removing the concrete. Any help would be greatly welcome. Thanks
RE: Removing concrete from galvanized threaded bolts
We have also forced the nuts down the rod and the concrete was pulverized without hurting the finish.
StoneCold
If you are going to NDT them it is best to remove the galvanized layer and re-apply using a field applied galvanizing paint or coating.
