2 story wood framed residence...header flush with 2nd floor framing?
Is this possible?
I'm not sure about breaking the top plates and how to reinforce the break.
The client wants a few window heads to stop right at the ceiling line.
Balloon frame to the roof in the areas of the flush headers?
RE: 2 story wood framed residence...header flush with 2nd floor framing?
You need to engage a local structural engineer on this.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
However, if it at the ceiling of the second story, it may be doable, but the framing would be more difficult and expensive, as well as possibly unorthodox.
A cross section would help.
Mike McCann
MMC Engineering
Breaking top plates isn't un-doable either - adding a strap with the correct capacity will be needed.
As stated, hire a structural engineer! :)
