Converting mass volume to mass flow
Hello forum. I'm new to Eng-Tips, so I hope I got this on the right board.
I'm working with a Cat 3516 gas engine on a low btu application. I need to spec a fuel metering valve to control mass flow to the engine and maintain my Air/Fuel ratio for emissions. I know the mass volume of gas (cfm) the engine needs based on the btu rating of our gas along with its SG. The metering valve will compensate for temp and pressure but is rated in Kg/hr. What I'm looking for is a formula to convert my mass volume to mass flow i.e: CFM to Kg/hr to determine the correct valve size.
RE: Converting mass volume to mass flow
You can down load the conversion from the below link..
http://www.katmarsoftware.com/uconflow.htm
If it is rated at ACFM then you need to get density at flowing conditions (compressibility may or may not be material). and multiply that density times the ACFM number. This is less common in equipment rating.
David
