Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Dudes! Great site. You've saved me hours and hours...and I have just started using your site. I've already passed your URL onto my entire company. Keep up the awesome work. Bingo-bango..."
Geography
Cubalibre00 (Mechanical)
10 Apr 12 15:45
I'm not able to obtain the right result.
I make the drawing of a motor with all components in the part list for our internal use. (motor drawing.png)
Now I make a drawing for our customer (spare part list) where the motor is included as sub-assembly.
I don't want to show all motor components, because we sell the motor, not the single component.
Which is the property to set to the motor .prt so in her drawing all components are listed in the part list, but if the motor is used as sub-assembly. (machine drawing.png)
I would like that every time I add this motor on an assembly, the part list consider the motor as a single component.
Thank you...
Using NX 8 and TC8.3
jerry1423 (Mechanical)
10 Apr 12 16:43
So will you have seperate drawings, in differnt files, for the customer and for you ?
beng021228 (Mechanical)
11 Apr 12 0:03
Does your machine drawing have subassemblies that you only want the subcomponents showing up in the parts list?  If not, in the first picture you see the levels settings for the parts list, I'm betting you'll get what you want if you select the "show top levels only" option.
11 Apr 12 4:10
think a automatic machine were in the assembly there are different type of sub-assembly.
There are sub-assembly like the motor that I don't want that the part list show her component and there are sub-assembly that I want to show only her components.
This type of sub-assembly are dummy sub-assembly.
Usually are sub-assembly created for convenient reuse or because they follow the real BOM.
I can't use the first levels part list option for this reason.
Thank you...
11 Apr 12 10:25
If you're allowed to, once you have these reuse subassemblies in possition you can yank the components out (dropping them into the top level assembly) and get rid of the subassembly (without saving the subassembly of course), that would allow you to use the "show top level only" option without having to go through each part that you want to add the PLIST attritbutes to.
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
