Template file of part family lost - only part family members available
I have a set of previously generated part family members in UG NX 5.0.3.2 but the template part was deleted by accident. Is there any way to save a particular size of the part family such that it can be edited?
For the moment, all I am getting notifications that I cannot make changes to the part family member and that all changes must be made to the template (seed) file.
Any advice will be greatly appreciated.
RE: Template file of part family lost - only part family members available
I found out by accident that if i run the refile command on a member only, it becomes a non family part and can then be edited.
 See other threads about the refile command.
Thanks for the tip. Unfortunately, the company I am working at does not run Teamcenter and has an old school File/Folder swap in/swap out system of maintaining CAD data. Is it possible to run 'Refile' without Teamcenter.
PS: Pardon my ignorance. I have never used the Refile command before.
Quote (aroy1984):
Yes. It is recommended to refile your parts when you upgrade versions of NX. There are 2 different versions of the refile utility: one for native setups, the other for teamcenter.
www.nxjournaling.com
Thanks for the clarification. Where in the Toolbars can I find the Refile command for native set-ups?
The refile utility is a separate program that can be found in the UGII subdirectory of your NX install. Search the help files on "refile part" for instructions on its use.
Did we lose a few entries in this thread?  I can recall replying to a post, but neither it nor my reply is here now.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
Quote (Toost):
Has anyone actually tried this and succeeded?
I just tried this using the NX 7.5 'refile_part.exe' with a single family table member and all I got was a nice new NX 7.5 version of what was an NX 5.0 Family Table Member part.  Nothing changed except the version of the file.
Now I didn't actually expect anything to happen since I've run refile for years on Family Table Members and I had never noticed any of them suddenly becoming write-able (no longer 'Read Only').
John R. Baker, P.E.
Industry Sector
Cypress, CA
Well, hm, i might be wrong here,
 The experience i have is when running under Teamcenter and it's sibling of the refile command where I think I managed to cut the connection between the template and the member by accident.
 I cannot test at this moment.
  Tomas
BTW, simply getting a 'non-read only' copy of the file is of little value if it does not include the original spread sheet data still intact.  After all, I can do a simple 'Save As' now and accomplish everything except the retention of the original Part Family data, so if your 'procedure' accomplished the same thing, it would be a lot of effort for little gain, like killing flies with a sledgehammer, the flies are dead but the furniture is in shambles winky smile
John R. Baker, P.E.
Industry Sector
Cypress, CA
