Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Your site is one of the cleanest and BEST forums that I have seen. I have sent quite a few people your way. Keep up the good work!!!"
Geography
BVPE (Structural)
10 Apr 12 9:17
I have been using the 9th edition AISC for I values for double angles.  When looking at the 13th edition, I am perplexed why I values are not given for double angles.  I see them for single angles.  Am I missing something?
frv (Structural)
10 Apr 12 10:02
It's just double that of a single angle bent about the same axis.
JoshPlum (Structural)
10 Apr 12 12:41
frv -
That's only true for one direction.  For the other direction, there is a re-location of the centroid....  So, it is not so straightforward to calculate.
If I had to guess, I would think it is a matter of AISC trying to keep the number pages down.  They want a single manual (as opposed to the two volume silver books) and they wanted a combined ASD / LRFD manual.  Therefore, some things had to get the axe!
frv (Structural)
10 Apr 12 13:41
JoshPlum-
I'm nut sure I follow.  For all cases of double angles either both angles are bending about the y axis or both angles are bending about the X axis. How would the centroid be affected?
MiketheEngineer (Structural)
10 Apr 12 13:43
Different size legs on the angles??
frv (Structural)
10 Apr 12 13:45
Mike,
Was that comment in response to the one I just posted?
10 Apr 12 14:18
frv -
Take a look at the ninth edition tables:
An 8x8x1 has an Ixx of 177 in^4.  That's exactly equal to twice the Ixx value for a L8x8x1.  Howerver, the ryy varies depending on whether the angles have a back-to-back spacing of 0, 3/8, or 3/4.  Since r = sqrt (Iyy/A) the I value changes based on the spacing, right?
For a LL8x8x1, the Iyy would be 346.8 in^2... That's approximately 4 times the Iyy value so a single L8x8x1.
msquared48 (Structural)
10 Apr 12 14:31
frv:
In one direction you are correct, but not the other due to the presence of a connecting plate between the angles, the space increasing the effective I and S.
If there is no plate then you are correct, but ususlly there is.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
frv (Structural)
10 Apr 12 14:51
I see.
I guess I wasn't picturing bending about the Y-Y axis as a "2L" case. I've actually had to calculate this value before, and I assumed that the reason this wasn't provided in the manual is because it would depend on the gap.
I don't have the 9th Ed., so it didn't occur to me that the Iyy value was specified previously.
Thanks for the clarification.
hokie66 (Structural)
10 Apr 12 17:23
Depends on whether the angles act together (compositely) or separately.  And there are lots of ways angles can be oriented, e.g. toes together like a channel, toes together to make a box, corners together to make a cross.  If anyone needs I for a non-typical configuration, just revert to first principles.
Close Box
Join Eng-Tips® Today!
Join Us             Close
