viewing help files with chrome?
Hello
How can I view NX help files with Google Chrome?
They are showed blank.
I have Javascript enabled and no adblock or spam filter enabled.
I can only view them using Internet Explorer.
RE: viewing help files with chrome?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
regards
This is sometimes an issue, also with other browsers.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit
However, when I go to help/NX help... it opens the help library and that one does work.
NX 7.5
Teamcenter 8
Best regards,
Michaël.
Win 7 64 bit
opening directly the html from the disk.
But I get a blank page.
I've read that the problem is that Chrome doesn't support Activex.
I've tried several Chrome Activex addons but don't work.
The only think that work is IE tab. This is like emulating IE inside Chrome. I would prefer to use Chrome natively.
Firefox works properly.
regards
Anthony Galante
Technical Resource Coordinator
NX4.0.4MP10, NX5.0.6, NX6.0.5, NX7.0.1, NX7.5.0-> NX7.5.5 & NX8.0.0 -> NX8.0.1
Or in some post i found this link to an add-on
[url]http
Best regards,
Michaël.
Win 7 64 bit
I've tested and neither of those options work.
I personally stick with Firefox.
Anthony Galante
Best regards,
Michaël.
Win 7 64 bit
John R. Baker, P.E.
Industry Sector
Cypress, CA
I like its extensions and customization and the way it uses memory.
Unless there is a way to select which browser you want to open (in NX, without affecting the rest of your system)...
NX 7.5
Teamcenter 8
Goto your shortcut to the chrome browser, RMB, properties, in the target field you will see the path to the install directory C:\..\..\chrome.exe
Add this to the path name ..\chrome.exe --allow-file-access-from-files
Click OK. There should be a space between .exe and --
Attached a screen shot.
Best regards,
Michaël.
Win 7 64 bit
Best regards,
Michaël.
Win 7 64 bit
NX 7.5
Teamcenter 8
instead of just chrome.exe
Anyway, this allows me to browse my computer files but I can't view NX files yet, the browser shows a blank page. I guess it's related with Activex.
I hope you mean that you would like to view the files like attachment or did i misunderstood you?
also type in the address bar the following :
chrome://plugins
and check if the Java plugin is checked (default is off) there are also some flash and shockwave plugins, i've enabled them too.
Best regards,
Michaël.
Win 7 64 bit
still no luck
I've read it could be an incompatibility with ActiveX
htt
Anyway is not serious, I'll use other browser
thanks
Locate the mainlibrary.html file and open it with the CTRL+O function, together with the previous recommendations you should be able to fire up the help files.
This type of problems has my interest
Best regards,
Michaël.
Win 7 64 bit
I have the file index.html
I'm speaking about NX 8
I've found this
http://cod
but I don't know how to configure.
