Difference between development and embedment
I have a question regarding the difference between development and embedment. I'm not sure I'm understanding the difference between the two. From ACI 530-08 2.1.9.3 (Development of bars in tension) and 2.1.9.4 (embedment of flexural reinforcement). What exactly is the difference? Let's say I have a beam with max moment at the center. I have to develop the tension reinforcement from that point of maximum moment. In this case Eq. 2-12 for development of tension reinforcement applies. Although the masonry code does not specify embedment length, ACI 318-08 says 12db past the point where no tension exists. Which applies? Is the embedment just a "safety" factor to make the sure bar is extended far enough?
RE: Difference between development and embedment
This is the definitions you were searching for (From canadian code A23-04):
Embedment length — the length of embedded reinforcement provided beyond a critical section.
Development length — the length of embedded reinforcement required to develop the design strength of reinforcement.
