SW Unable to obtain required memory warning
Every once in a while I get a warning window that appears, usually in the middle of an operation,
that says, "Solidworks unable to obtain required memory" and usually has 2 buttons that say "RETRY"
or "CANCEL".....no matter which button is pressed....then the program will quit. Any help or suggestions what this window is telling me and how to avoid it?..... Usually there are no other programs running. I'm running SW 2011 , 3 gigs ram, WindowsXP 2002sp3. Thanks for any help.
RE: SW Unable to obtain required memory warning
Try opening and closing SolidWorks more often during the day or get more RAM and Windows 7 x64.
Cheers,
Anna Wood
SW2011 SP5, Windows 7 x64
http://www.renderbay.com
http://www.solidmuse.com
http://www.phxswug.com
thread559-155411: 3GB Memory Switch..
It's just this particular file that is causing the problems. Thanks again.
Anna Wood
