Thermodynamics (vapour pressures @ different relative humidities)
Hello bright minds,
I have been searching for vapour pressures at +55 degrees celsius from 10 % relative humidity up to 100% relative humidity, and I have trouble finding these values, even on the physcometric charts that I find. Have anyone any good input to this, or what the vapour pressure is at these 'states', please give me our feedback!
Thank you in advance
BR
Dan Anderson
-You only live once, but if you work it right, once is enough!
RE: Thermodynamics (vapour pressures @ different relative humidities)
At 55C water has one fixed vapor pressure. The partial pressure of water vapor will vary with relative humidity.
50%RH means that the partial pressure of water vapor in the air is equal to 50% of the vapor pressure of water at 55C.
Psychrometric charts are derived from the vapor pressure vs. temperature curve for water.
