fully closing a steel support - problems?
I'm fabricating 4  steel columns that will serve as a replacement for 4 wooden posts which support a roof similar to a carport.
It will need to be welded onto a baseplate (with bolt holes), and I intend to weld the upper end shut as well.
This won't be hot dipped nor powdercoated afterwards, only painted.
Should I worry about any moisture inside, as I'll do this at home, no special controlled environment nor the ability of drying the inside to a 100% dry.
The upper end will be protected for the rain by the roof.
So should I have weep holes, those at the bottom are more likely to see water entering from rain "ricoshet", and I can't really paint the inside. According to me I'd be better off without.
Your thoughts?
RE: fully closing a steel support - problems?
Put a small weephole in the baseplate. Better safe than sorry.
I would leave it sealed.
I would prefer sealed too, but what would the "sorry" option mean?
If there was an initial small amount of water inside, how much would/could it corrode?
Rust = oxides, so once all the water is transformed into oxides, it should stop rusting, no?
Rust is a reaction with oxygen in air. Water just facilitates the reaction.
Keep it sealed.  Slight corrosion inside will consume remaining oxygen and further corrosion will cease.
Sealed.
Extra paint near the bottom, or gutters and downspouts to deal with rain ricochet.
Mike Halloran
Pembroke Pines, FL, USA
Thanks for your thoughts...
Sealed it will be.
I'll blow through the steel columns with a hair dryer for piece of mind...
