Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Praise should be given to the Forum managers or the Tipmasters - they are what make it work - give them extra recognition!!! They are timely (prompt - unlike ACTUAL support sites) and on the ball!!!..."
Geography
cyoungs (Industrial)
7 Apr 12 10:39
Does a welders qualification test plate have to directly resemble Fig 4.30 for FCAW Horizontal qualification on 1" material or instead of using a backing bar, can a double bevel with the parent material used as backing, then backgouged to sound metal, be used, similar to qualifying on a production weld. Does that test plate still only have to be 5" long.
Helpful Member!  gtaw (Structural)
7 Apr 12 15:41
The welder performance tests are not intended to simulate production welds or production conditions. The tests prescribed by the code are the minimum requirments for welder qualification.
If the employer feels that it is prudent to require additional testing to simulate the production requirements, he is free to do so. However, any tests that simulated production requirements is in addition to the prescribed tests defined by the applicable code. They are not a substitute for the prescribed tests.
Best regards - Al
Close Box
Join Eng-Tips® Today!
Join Us             Close
