CTS antenna and Thinkom
Do anybody hear about the Continuous Transverse Stub (CTS) antenna or Thinkom before? This antenna look like the best candidate for the millimeter integrated radio, depicted as 50% wider in bandwidth, 20% higher in efficiency, 6 to 15 dB lower in sidelobes, 70% lower in profile, 40% lighter in weight, and 50% lower in cost than the shrouded- and steep taper-parabolic dishes it replaces.
But The ThinKom claims completely own the intellectual property of CTS antenna. I want to know if there is some other company also provide this kind of antenna.
Related pdf is attached
RE: CTS antenna and Thinkom
The bandwidth shown in the graphs (37 to 40 GHz) as a percentage bandwidth is good, but not amazing. At these frequencies, the loss is typically so high that VSWR itself is rarely a direct problem. But loss is so high that one wouldn't want to exacerbate it with high VSWR.
Being extremely high gain, they're obviously intended for fixed point-to-point links. Such applications are often installed in locations (e.g. part way up a tower) such that a simple dish installation is perfectly acceptable. Obviously the mm-wave radio itself needs to installed right there, or preferably integrated, to mimimize loss.
If it's really "50% less expensive" than the alternative technologies, then there's no need to avoid them.
"Invented in 1991" is 21 years ago. Not many were working in mm-wave radio (e.g. 40 GHz) in 1991. Some, researchers, but not many.
Their earliest patents must be getting ripe by now. Of course, they'll have layered on additional patents in the meantime. If you can find their patents at USPTO.gov, then you could follow the links (prior art, both backwards and forwards) to find others working in the same niche.
As a system designer, you could pretend to ignore the technology inside their antenna subsystem and simply focus on the performance (air interface, physical characteristics, etc.)
Here's another one: http://www.google.com/patents/US5771567
Notice the 'Citations' and 'Referenced By' sections. The 'Referenced By' list leads you forward in time to the others in the same niche.
attached is the IEEE file
At zenith, its polarization is dependent on the azimuth pointing direction, so it can be rotating linear at zenith.
It needs a polarizer for circular polarization since it's inherently linear polarization.
It can do endfire V pole efficiently, but to get H pole or good circular, it'd have to sit up high above the surface that it's mounting on.
Looks like a good option for higher frequencies due to the lower loss in the distribuiton across the aperture with it's slow wave structure.
