Need your Help- Compressors small bore piping failure
Please help me understanding the following:-
It appears in my plant when small pipings is connected to large bore piping on the discharge of a rotating equipment, the vibration stress appears to cause fatigue in the welds at the small bores?
what is your advise?
At what piping size ( 2'' or so maybe), the support shall be enforement.
The application is Centrifugal Compressors.
RE: Need your Help- Compressors small bore piping failure
What would you be doing, if you knew that you could not fail?
Also, Which distances between supports?
2 meters
Johnny Pellin
