Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...One of the best run forums I have used in years! ...I like the way the site is organized and your no tolerance of flames..."
Geography
A/C performance data for lower air flow
cpjeffc (Mechanical)
6 Apr 12 16:45
I am working on a heat load calculation for an HVAC system.  The system is installed and operational, so I am revising the calculation to include new heat loads in the area so that I may determine that the existing HVAC system is capable of adequately cooling the area.
The problem is, that the previous revision of the calculation I am working with seems to have been wrong.  So I am starting it fresh.
Vendor information for the A/C unit provides cooling performance data for cooling at 2,700 cfm, 3,000 cfm, and 3,300 cfm; however due to a supply side fire damper, flow is restricted to 1,700 cfm.  Is there a way to calculate the Total Cooling and Sensible Cooling for a lower flowrate, given the same outside air and return air conditions?
I have linked the PDF for our A/C unit.
Thanks in advance for any help.
317069 (Mechanical)
7 Apr 12 3:06
cfm is load calculation output not input.
you calculate your load first then you define the cfm required.
after that you check unit data or talk with unit munufucturer.
but I didn't understand that you are not able to go over 1700 cfm because of fire damper?
Close Box
Join Eng-Tips® Today!
Join Us             Close
