Residential Cooling Loads - Plug load
I dont work with residental HVAC designs much.
I have a 800 SF unit with 3 exposed walls (r-6 wall, r19 attic insul). I can up with 1.3 tons (about600 sf/ton).
I used .7 watts per SF lighting and .5 watts per SF plug load. Are these reasonable values for a residental unit?
Is the overall tonnage seen resonable? (I would use a 1.5 ton unit).
RE: Residential Cooling Loads - Plug load
TTFN
in residential lighting is not ON all the time like commercial, especially in day time.
