hydraulic pipe calculations in conceptual or basic design phase
L.S.,
Somewhere I read an article about how to make hydraulic pipe calculations with limited information during the basic design. It gave some guidelines about how to estimate the amount of bends and other things causing pressure loss based on the pipe length.
I don't seem to able to find it. Is there someone out there, with whom a bell starts ringing, while reading this? If so, I really would like to get a copy of the said article. If there are any literature sources on this subject that might be interesting I am all open for it.
With best regards,
With best regards,
Karel Postulart, The Netherlands
Nuon Power Generation
RE: hydraulic pipe calculations in conceptual or basic design phase
If you're talking for a typical pipeline, I might reserve 2.5 to 5% for losses at a station.
What would you be doing, if you knew that you could not fail?
Might you be thinking of the Crane Technical Paper 410 "Flow of Fluids?" Not much good for the oil pipelines that BigInch works with, but pretty decent place to start for something smaller.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
If it's within a unit, I've allowed 10 psi for piping line losses. For supply/rundown lines to tankage, 20 to 30 psi. You then add elevation, instrumentation and equipment pressure drops as necessary.
Piping within a unit is usually designed for a few psi/100' so 10 psi gives you a reasonable allowance for straight line losses.
If you have a plot plan, then I've scaled off where I think it's likely how piping will run the pipe to get the straight run piping, add elevations) and then add 20% to 50% for fittings to estimate the line losses. If you have a convulated piping configuration you can increase the fitting allowance but I think 100% is about as high as I would go for fittings. Piping to/from a tank farm would be at the lower end for fitting allowances and for a pipeline as BigInch says, it's minor.
