adding krx in fastener command
i was wondering, and probably it's possible, but i have no idea how i can do this:
i want to create a fastener assembly with this part:
http://www.q-parts.nl/catalog/images/857620.jpg
sorry, my native language is not english and i can't find the english word for it. sorry for that.
can i create this part as a KRX file and input it in to the reuse library so that the fastener assembly command can see my own made part? cause right now it only sees the parts that are already integrated in NX.
Best regards,
Chevy
NX6
Win7, 64 Bit
RE: adding krx in fastener command
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
i will look in to it.
Best regards,
Chevy
NX6
Win7, 64 Bit
but the only usable item in that file is the word document right? cause the 2 .prt's are nothing and i can't open the .dpv(also have no idea what it is)
Best regards,
Chevy
NX6
Win7, 64 Bit
John R. Baker, P.E.
Industry Sector
Cypress, CA
i was wondering in the part i posted earlier is in the Machinery Library? i was looking for it to download, but couldnt really find it on siemens website or on google, could you help me out with that? is it a handy library?
Best regards,
Chevy
NX6
Win7, 64 Bit
would also wanted to say that on page 11 at the bottom:
it says: "Thinckness"
don't know if u can edit it, but i think it should be thickness right:P?
thnx for the information though!
Best regards,
Chevy
NX6
Win7, 64 Bit
John R. Baker, P.E.
Industry Sector
Cypress, CA
is there a way to ge those Machinery library parts in to the Fastener command?
Best regards,
Chevy
NX6
Win7, 64 Bit
If so, when you pre-define typical Fastener 'stacks' using the 'Configure Fastener Assembly' function, based on the Standard selected, you will have access to the various relevant fasteners from the Reuse Library.
Search the NX Help files for 'Fastener Assembly' (or open the 'Configure Fastener Assembly' dialog and press the F1 key) and you will find stuff which will help you set-up these fastener 'stacks'.
John R. Baker, P.E.
Industry Sector
Cypress, CA
thank you!
Best regards,
Chevy
NX6
Win7, 64 Bit
when i press F1 or go to the help files, i get this error:
"Unable to display help information.
Application contect not found"
is this because we use multiple HD's and NX can't find the help files?
Best regards,
Chevy
NX6
Win7, 64 Bit
Should be a (network) HD path like this :
UGII_CSHELP_DOCS "path to help files"
Probably it points to the wrong directory or network path.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit (Intel(R) Xeon(R) CPU X5650 @2.67GHz)
24.0 GB
NVIDIA Quadro 4000 + NVIDIA Tesla C2050
but the "ugdoc" map doesnt exist
Best regards,
Chevy
NX6
Win7, 64 Bit
Best regards,
Michaël.
24.0 GB
Best regards,
Chevy
NX6
Win7, 64 Bit
https://d
You need a valid webkey and login for this site.
Best regards,
Michaël.
24.0 GB
Best regards,
Chevy
NX6
Win7, 64 Bit
it doesnt say anything about putting hex socket bolt in..
only this: Use this command to add an individual fastener or Fastener Assembly (bolts, screw, nuts, and washers) into selected holes automatically. The fasteners are retrieved from the NX Machine Library, which has a large variety of ANSI, Inch, Metric, ISO, JIS and other standard hardware. The fasteners are fully parameterized NX parts.
but i only have acces to the normal hex bolt and nut.. (see attachment)
so how do i put those others bolts and nuts in? since i only have the basic nut and bolt..
Best regards,
Chevy
NX6
Win7, 64 Bit
Best regards,
Chevy
NX6
Win7, 64 Bit
John R. Baker, P.E.
Industry Sector
Cypress, CA
1, see attachment, the machinery library isnt added, but when i add it nothing happens when i press on the add button [2](see attachment which button i mean)
2, maybe it has to do something with the wheel between the return and X button on your screen which i have not..(also see attachement)
Best regards,
Chevy
NX6
Win7, 64 Bit
I don't know what to say if you have the Machinery Library installed where it supposed to be and if you have no problems find what you're looking for by going to the Reuse Library tab on the Resource Bar.
John R. Baker, P.E.
Industry Sector
Cypress, CA
thats the problem.. i haven't i just added the map since i cant go in my C disk cause we have alot of stations here and im just an intern and looking for this kind of stuff to help the company out.. everything is locked.. in which map should the directory be in then?
Best regards,
Chevy
NX6
Win7, 64 Bit
Customer Defaults -> Gateway -> Reuse Library -> General
...and in the appropriate section, Native or Teamcenter, check to see if the correct paths have been defined to where the libraries were installed.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Best regards,
Chevy
NX6
Win7, 64 Bit
2. Copy the zip files to "${Installation_Tool_Root}\Tool\libs" folder.
this folder is the folder within the download, so where do i put this directory?
since, i cant go further, ive got no idea how to get the picture in step 3..
can somebody help me with this?
Best regards,
Chevy
NX6
Win7, 64 Bit
