MTR Certification Requirements
I have recieved some suspect 304H pipe from an Asian mill. The MTR's are not signed or stamped.
Is this a requirement? I don't recall ever seeing MTR's without a signature.
RE: MTR Certification Requirements
Mike
No, there is no requirement.
Review ASME SA 530, specifically under 21.1 Certified Test Report
When specified in the PO or contract the producer or supplier shall furnish a Certified Test Report certifying that the material was manufacured, sampled, tested and inspected in accordance with the Specification, including..... A signature or noterization is not required on the Certified Test Report.....
I have a bridge in NYC that I want to sell. Boy, have I got a deal for you!
Best regards - Al
I think that this is the least of your worries.
Do a chem and a micro to check grain size for starters. You might also take some dimensions and see if it is the correct size.
Plymouth Tube
