User defined feature library setup
In my spare time I'm tring to search though differnt operators/commands thatour organisation isn't using and see if we can use them to address various problems we're having.
so I've decided to check out user defined features.
Problem is I don't have access to write to the default directories and therefore canot create any UDFs to try out.
is there a way for me to ste up a temporary directoryto save my UDFs in?
RE: User defined feature library setup
this is my opinion, but UDF's features are obsolete, replaced by the reuse library.
Thank you...
Using NX 8 and TC8.3
Copy the NX icon onto your desk top
right click on the icon and select properties
on the shortcut tab enter the start in path.
When you create a udf it will store it there , at least that's how it works for me on Win7 NX 6
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6.0.5.3
are you sure that reuse library can't offer what you need ?
Please post a better description or file or image of what you need.
Thank you...
