Part list order chaning when I change the description
Whenever I have to add something to the description in my parts list, the order of the components change. I was wondering how I prevent this, I would prefer that item 1 will always be item 1.
RE: Part list order chaning when I change the description
www.nxjournaling.com
NX 7.5 : RMB the partslist - Style, in the bottom there is an option "Sort on Update".
And:
RMB the parts list - Sort, here you can set which column that should be primary /secondary etc and if that column should be used or not etc.
I tried lock row, but if I manually change the description, the row gets a line though it and a new row is added on top.
When clicked or clicked off sort on update , the row that I changed still went to the top of the table.
I also unselected any of the checkmarks for sort, and it didn't work.
I am making manual edits to the description and what ever changes automatically gets put on top. It's nice feature, but I can't use it if it does this.
