Bug with offset and corners NX 6
i wanted to share this with you guys.
plz look at the attachment:
its a square with round corners and an offset on the inside.
as you can see i used some expressions. if u change the thickness to 3, a bug appears. but if u change it to 2, and then to 3. its the way its supposed to be.
i dont know if this is a known bug, and i had no idea how to search for this if it was already posted, sorry if it was, but test it yourself. and does anyone know how this is possible?
so.
open the part.
change the thickness to 3 and see it yourself
but when u make it 2 and then 3, its good.
awkward don't you guys think?
when i dont use the offset but make a square with constrains and midpoints etc,(so you have the same idea as an offset) you can change it from 1 to 3 without problems.
so.
open the part.
Best regards,
Chevy
NX6
Win7, 64 Bit
RE: Bug with offset and corners NX 6
Have a read of this thread ... http://www.eng-tips.com/viewthread.cfm?qid=212859 ... specifically the last post from John Baker.
NX 6.0.5.3 (NX 8 Testing)
Windows 7 64
thnx=]
Best regards,
Chevy
NX6
Win7, 64 Bit
