Inventor templates
Inventor templates
Inventor templates
I got the. Idw template saved to the default location, with help from thus forum, but now when I create a drawing the file name is not updated into the field in the lower right corner. I can get around this but is there an easy fix for it to load the name of the part model into the drawing? And thanks for the help on this! I can do most of what I want in Pro tE but Inventor is new to me.
RE: Inventor templates
iProperties in the model must match the name in your template.
Standing
AutoDesk Inventor 2012
SolidWorks Pro 2010 x64, SP5.0, SolidWorks BOM,
HP xw8600, 64-bit Windows 7
Intel Xeon CPU, 3.00 GHz, 16 GB RAM, Virtual memory 166682 MB, nVidia Quadro FX 4600
Open your template and edit the title block. Edit the text you want to automatically update (part number). Set the drop down for "Type" to "Properties - Model" then the "Property" drop down to "PART NUMBER". Then click the button with an "X" and a down arrow on it to insert it into the text. It should show up in the text box as <PART NUMBER>.
Save you template and try adding a part.
msadie,
Very well said. A star for you.
Standing
