Deformable Part problem
I have defined a deformable part, which I am trying to deform in an assembly context four assy levels above the part model. However, when I try to do this, I get the error message:
"Unable to deform because deformed parents of component exists"
Can anyone tell me what exactly this means, and how to locate these "deformed parents" and delete or revise them so I can deform the part in this assembly?
By the way, my data is managed in Teamcenter, which will probably complicate things. It usually does!
Thank you - tomc
