Aluminum or StainSteel Insulation Covering??
My current Client allows different Environmental credits for external Fire - depending on the type of insulation covering.
Aluminum has value "X" and Stainless Steel has value "Y".
I'll typically hire a Pipe technician to complete a field survey prior to doing a vessel safety valve evaluation.
One of his tasks is to determine the types of insulation covering for correct application of the Environmental credit.
My problem is teaching the technician how to determine the difference between aluminum and SS.
I'll admit that even I have ocassional problems myself.
Does anyone have a "sure fire" method to tell the difference??
RE: Aluminum or StainSteel Insulation Covering??
-If it melts, its aluminum
-If it does not melt it is Stainless Steel
"Don't overthink simple problems"
