Save failed- file in use by another process
occasionally i get this message while in native. there are no other users or sessions open. what is the cause ? is there a setting? i am using NX 7.5.3.3
only thing i can do is save as.
i have seen this on both a stand-alone system or even networked with teamcenter.
Scott Copeland
Design Engineer
Persego Int'l
www.persego.com
RE: Save failed- file in use by another process
There was an issue to do with facet loading that was fixed in NX7.5.4 and above. I would recommend updating to that MR or NX7.5.5 first.
Anthony Galante
Technical Resource Coordinator
NX4.0.4MP10, NX5.0.6, NX6.0.5, NX7.0.1, NX7.5.0-> NX7.5.5 & NX8.0.0 -> NX8.0.1
ok thanks
i don't see us moving up to that level- corporate decision, so i guess we just have to live with it for now.
thanks for your respondse.
Scott Copeland
Design Engineer
Persego Int'l
www.persego.com
I had the same issue,
there is a customer default setting for assembly has infuence on the problem, uncheck the seeting for display warning on write protected parts
reagards
ok i'll check out the settings and see
Scott Copeland
Design Engineer
Persego Int'l
www.persego.com
