Saving assembled parts on same coordinate system
I have been given 20 CATIA part files. I have created a CATIA product with them all correctly aligned using the constraints feature. It is a casting die, so it is important that the surfaces of each part qare correctly aligned with one another.
I would like to export each part as an .STL in order to import them into a CFD software. I want to export them using the same coordinate system so that they are correctly aligned when imported into the CFD modeling software. How do i do this?
I have used solidworks before, in which you have the option when saving as an .STL of using either the part or assembly coordinate system. However, I don't see a similar feature in CATIA, and can't work out another way of acheving the same thing.
I am using CATIA V5 R20
Any help would be gratefully appreciated.
RE: Saving assembled parts on same coordinate system
Derek
Win XP64
R20/21, 3DVIA Composer 2012, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
