Hydraulic Motors in Series
We have an application where I keep blowing seals on hydraulic motors and I was hoping to get some assistance. The machine grinds a hay bale for feeding cattle.
Our application requires two hydraulic motors to be plumbed in series. The two motors have different displacements (14.7cu-in and 18.7cu-in). Our customer claims they are using case drains.
Any ideas why the motor seals would be blowing? Is plumbing two different displacement motors in series not a good practice?
RE: Hydraulic Motors in Series
You need to check that the motor case drain connections are really being used correctly and that your customer hasn't inadvertently connected them to a place other than tank. Also check that there aren't any isolation valves or non-return valves in the case drain line. If this is a system connected to the HPU/tractor via quick release couplings then check that the drain line quick release couplings are properly matched/mated and that the internal check valves in the couplings are opening properly. If the lines are a little small and the oil is very thick (cold start-up) then just the back pressure could be enough to push out the shaft seals. Is it possible for you to tee in a pressure gauge right next to each of the motor case drain ports? This would let you check the case pressures directly and see if the problem was from something external to the motor.
But if the problem isn't in the execution it might be in the circuit design or the component selection. What make/model of motor are they? The particular sizes make me think of the Sauer Danfoss OMP range but there are lots of similar products. Do the motors have to run in either direction? Do they ever have to stall? What is your system pressure? Do the motors run at high speed with a high inertia load on the shaft? Do the motors have any cross port relief protection? Can you post a circuit diagram?
DOL
In addition make sure the motors are fitted with high pressure seals, not the common 40-50psi shaft seal. The key will be to make the case return lines as non-restrictive as possible. The case drains can be connected to the same return line as the outlet of the downstream motor if the motors are not run in reverse. This line should be at least the next size larger than the pressure line. e.g.; 1/2" pressure, 5/8" or 3/4" return.
What is the maximum flow rate? What is the hydraulic fluid? Does the return flow go through a filter before entering the tank?
Ted
