Autodesk Inventor
Autodesk Inventor
I need to save a default title block that can be used each time I create a drawing from a part model. I have a title block from another drawing I want to save and alter slightly. How do I carry this out?
RE: Autodesk Inventor
You might want to use the style library wizard to create a style library from your existing drawing file. Or just modify the default as you go and update your templates to suit.
