Split Line Single Side
I should be obtaining a total of two faces after the split line feature with "Single Side" is completed on the attached part. However, the resulting feature has three faces. Please advise.
TIA - battle
TIA - battle
RE: Split Line Single Side
If you place the ellipse sketch on the Top Plane, you will also get what you want.
