Custom holder retrieves from library
Dear All,
I added the following rows to the end of the holder_ascii.def file:
CLASS GRAPHIT_MILLING
TYPE QRY
QUERY "[DB(Type)] == [03]"
DIALOG libref Type
RSET libref Description N_Sections Max_offset
UI_NAME "Graphit_Milling"
CLASS MILL_1
TYPE QRY
QUERY "[DB(SubType)] == [0]"
DIALOG libref Description
RSET libref Type Description
UI_NAME "Mill_1"
CLASS MILL_2
TYPE QRY
QUERY "[DB(SubType)] == [1]"
UI_NAME "Mill_2"
I added the following rows to the holder_database.dat file:
DATA | GR_ZSUG001_00001 | 1 | 3 | 0 | 3 | 0.00000 | 0.00000 | 0.00000 | Small collet
and
DATA | GR_ZSUG001_00001 | 2 | 1 | 44.00000 | 25.00000 | 0.00000 | 0.00000
DATA | GR_ZSUG001_00001 | 2 | 2 | 40.00000 | 27.00000 | 0.00000 | 0.00000
DATA | GR_ZSUG001_00001 | 2 | 3 | 64.00000 | 15.90000 | 0.00000 | 0.00000
I added the following rows to the holder_ascii.tcl file:
For the proc Asc_load_holder_data:
if {$dbc_holder_type == 3} {
ASC_load_milling_holder_data
For the proc ASC_retrieve:
#milling holder
set dbc_holder_num_sections [ASC_ask_att_val \
SNUM $db_row "%d" 0 flag]
set dbc_holder_max_offset [ASC_ask_att_val \
MAXOFF $db_row "%g" 0 flag]
set dbc_holder_min_diameter [ASC_ask_att_val \
MINDIA $db_row "%g" 0 flag]
set dbc_holder_max_diameter [ASC_ask_att_val \
MAXDIA $db_row "%g" 0 flag]
And the end of the proc Asc_load_holder_data:
For checking:
MOM_log_message "A konkret sor 0 seq-e"
MOM_log_message $dbc_seqno(0)
MOM_log_message $dbc_hld_diam(0)
MOM_log_message $dbc_hld_hgt(0)
MOM_log_message $dbc_hld_taper(0)
MOM_log_message $dbc_hld_corner(0)
I can see the following rows in the syslog file:
************* MOM: TCL SCRIPT MESSAGE *************
User message: A konkret sor 0 seq-e
User message: 1
User message: 44.00000
User message: 25.00000
User message: 0.00000
So, I think everything is correct.
But these values don't set on the Holder tab of the Milling Tool - 5 Parameters dialog window.
Every values remain 0.0000 in every cells on this dialog window.
What is my mistake?
Thanks a lot.
TYPE QRY
DIALOG libref Type
CLASS MILL_1
TYPE QRY
UI_NAME "Mill_1"
CLASS MILL_2
TYPE QRY
UI_NAME "Mill_2"
and
#milling holder
For checking:
User message: 1
What is my mistake?
Thanks a lot.
RE: Custom holder retrieves from library
Can you create a holder in NX and export it, selecting one of your classes?
You may get more help from the Siemens PLM customer forum, or GTAC.
Mark Rief
Product Manager
Siemens PLM
IR 1893965 - Custom holder retrieves from Library
The log contains the every necessary files and one video file from the workflow.
Attila Szepesi
support engineer
graphIT Ltd.
www.graphit.hu
