NX Journal - Test for B-spline surface Closed or Not?
How do I determine from the askbsurf (or other information) if a B-surface/parametric surface is closed  (ie. like a tube)?
Jeff
RE: NX Journal - Test for B-spline surface Closed or Not?
One simplistic method would be to count the number of edges. If there are only 2 edges, you have a tube-like surface.
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UI
Imports NXOpen.UF
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim lw As ListingWindow = theSession.ListingWindow
        Dim body As Body = Nothing
        lw.Open()
        While select_a_sheet_body(body) = Selection.Response.Ok
            lw.WriteLine("Number of edges: " & body.GetEdges.Length)
        End While
    End Sub
    Function select_a_sheet_body(ByRef obj As Body)
        Dim ui As UI = GetUI()
        Dim mask(0) As Selection.MaskTriple
        With mask(0)
            .Type = UFConstants.UF_solid_type
            .Subtype = UFConstants.UF_solid_body_subtype
            .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SHEET_BODY
        End With
        Dim cursor As Point3d = Nothing
        Dim resp As Selection.Response = _
        ui.SelectionManager.SelectObject("Select a sheet body", "Select a sheet body", _
            Selection.SelectionScope.AnyInAssembly, _
            Selection.SelectionAction.ClearAndEnableSpecific, _
            False, False, mask, obj, cursor)
        If resp = Selection.Response.ObjectSelected Or _
           resp = Selection.Response.ObjectSelectedByName Then
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
 'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
    End Function
End Module
www.nxjournaling.com
Interesting solution.  Unfortunately, if the "ends" of the tube consist of multiple edges (eg. a locating notch in the tube) then it will report more than 2 edges, yet it is still a closed surface.
I'm thinking more in terms of the poles & knots of a b-surface, but I can't remember how to use that to define if it is closed or not.
Jeff
I ran across this function today:
NXOpen.UF -> UFModl -> AskFaceTopology Method
I have not tried it out, but it looks like it may help get the info you are looking for. Not the total solution, but maybe a piece of the puzzle.
Being that I don't write NX Open programs I'm not familiar with what the function you mentioned does but if it does provide useful information one key word you might look for is the term 'periodic'.  A surface, such as a cylinder, which 'wraps' around and meets itself without a seam or edge, like a piece of 'seamless tubing', is said to be 'periodic'.  Generally speaking, NX creates ALL cylindrical faces as periodic faces, something that is not done in many other systems, including Catia, and at one time, Pro-E (this may still be true just that I haven't seen any new Pro-E parts recently).
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
I used AskFaceTopology and that seems to work well.
Jeff
A open surface has end knots at 0 and 1.  A closed surface has end knots at < 0 and > 1.  For example consider a closed surface representing a square extrusion then for the square section we would have four degree 2 segements and the knot vector would be {-0.25,0.0,0.0,0.25,0.25,0.5,0.5,0.75,0.75,1.0,1.0,1.25}.
So if you get the surface properties and determine the end knots you have another method for determining open or closed status.
Frank Swinkels
