Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...If there has ever been a justification needed for access to the net during working hours, just referring to this site should suffice. Fantastic!..."
Geography
babelfish (Chemical)
3 Apr 12 5:16
I'm looking for somebody that has experience of using spring hanger pipe supports for pipes on to vessels that are on load cells.
We have been through this with our pipe stress engineers and they believe it is fine, as an alternative to using bellows/flexible.  The problem is our end customer is not convinced and "expects" bellows.
I'd like to find somebody who has experience of using of using spring hangers instead of bellows that can ideally say, "Did that and it worked just fine".
"Are we speaking the same language?...engineering - it's the appliance of science."
MiketheEngineer (Structural)
3 Apr 12 10:41
You might want to un-post here and try "Pipelines" or "Structural" forums if you get little response??
3 Apr 12 11:46
@Miketheengineer, I've posted in pipelines as well but my try structural too.  I appreciate this is a long shot and multiple posting is poor etiquette, but I know I've got to cast the net wide.
SNORGY (Mechanical)
3 Apr 12 13:03
I don't have an issue with it, but you will need to compensate for the loads imparted to the spring hangers as they will affect the measured loads versus the actual loads on the load cells.  This may be a good application for constant effort supports?
SNORGY.
BigInch (Petroleum)
3 Apr 12 15:39
You can usually make constant load spring hangers work for most any installation you have problems with.  Can't say the same for problem clients though.
What would you be doing, if you knew that you could not fail?
StoneCold (Chemical)
4 Apr 12 9:40
I think that it would depend a lot on the size of the tank in question and the level of accuracy that the client was looking for.   Do you think that you can provide the same level of accuracy with the spring loaded hangers and straight pipe as with the flexible hose sections?
StoneCold
Close Box
Join Eng-Tips® Today!
Join Us             Close
