settlement in airport
the settlement of concrete plate around foam room after some months in apron area?
RE: settlement in airport
Yes. Certainly appears to be settlement.  Do you have a question?
how we can improvement the settlement of concrete mat foundation?
does the bad compaction soil under slab mat foundation case the crack and settlement?
NO.
The load on the top of the slab, copmbined with the lack of compaction and the fact that the matt was not designed to span the area caused the cracking.
It's not just one thing here.  It's a combination of things.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
Agree with Mike...investigation required to determine the multiple probable causes.
Dear Ron & msquared thanks for your guides
