Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...(I) have been able to get my problems solved from past messages and also new posts that other users have responded to promptly..."
Geography
fe2655847 (Mechanical)
2 Apr 12 20:12
API 610 para 7.3.4.7.1 states that pump, if specified, shall be run on the test stand until oil temperature stabilization has been achieved. Is VS4/VS5 grease-lubricated pump covered in the statement?Is "grease" covered in the word "oil" in the paragraph?I think grease and oil are different.
Thank you.
JJPellin (Mechanical)
2 Apr 12 22:07
Grease is composed of oil plus thickener.  Thickener does not lubricate the bearing.  The bearing is lubricated with oil.
It says "if specified."  If you want this test requirement, specify it.  If you do not want it, do not specify.
For grease lubricated ball bearings, I would not specify this requirement
Johnny Pellin
bimr (Civil/Environmental)
3 Apr 12 9:18
Grease is not covered. Grease is used to describe semisolid lubricants.
Oil viscosity changes with temperature. When temperature rises, an oil becomes less viscous. Hence, the temperature must be specified whenever a certain viscosity of a liquid is required.
Pumpsonly (Mechanical)
5 Apr 12 12:47
The extended mechanical run test is to check bearing loading is not excessive. Over loaded bearing will have temperature keep on rising.
 During mechanical run test,the oil temperature or the bearing housing temperature for grease lubricated bearing are recorded at a fixed time interval. A Temperature Vs Time graph is plotted until the graph goes flat.. indicating the temp. has stabilised.i.e heat generated = heat dissipated.
The temp. rise over the ambient temp will be checked if it is within the limit specified.
Grease temp. is not mentioned because para 5.11.1 states, "unless otherwise specified, bearings and bearing housing shall be designed for oil lubrication...."
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
