Modeling curves no longer display in drafting views... NX8
After the upgrade I've noticed I can't do this.
I'm sure this is some new switch I can't find.
Anyone know how to fix this?
TIA
Dave
TIA
Dave
RE: Modeling curves no longer display in drafting views... NX8
Maybe you have changed the method to create drawings.
If you use master model approach, what you see in the drawing is pilot by the reference set used in the drawings.
If you don't use this method (switching to drawing application from modeling application), what you see or not is pilot by layers.
Thank you...
Using NX 8 and TC8.3
Wich version did you use before upgrading to NX8 ?
Didier Psaltopoulos
http://www.psi-cad.com
It doesn't appear to matter wether I add curves to the reference set displayed or to model space of the drafting file... neither one seems to display.
Yet if I open a legacy file where I've done or both they appear in the drafting views.
I'll have to explore a little further... any help is always appreciated.
TIA!
Dave
If so, have you tried using...
Format -> Layer Visible in View...
...to reset the views so that all layers are visible?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
