Bolt Materials
Bolt Materials
I have referenced that Class II (specifically B7M) bolting may have a 20% reduction in tensile strength compared to Class I or standard bolting materials and may also reduce the allowable working pressure in some cases. Is there a rule of thumb or specific reference to determine acceptable design measures when utilizing B7M bolting versus standard B7 bolting for standard flange joint, flanged valves, compressor cylinders, and cooler connections?
RE: Bolt Materials
prex
motori@xcalcsREMOVE.com
http://www.xcalcs.com
Online tools for structural design
RE: Bolt Materials
