What type of Nylon?
What type of Nylon?
Does anyone know what type of nylon and rubber is used in this product http://www.josephjoseph.com/kitchen-tools/elevate . It states it is heat resistant to 240˚C/480˚F. Also what is the manufacturing process called in which a plastic is coated in rubber?
RE: What type of Nylon?
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Thanks to ON, I just saw the second part of the question.
The rubber is typically polyurethane and the nylon having the higher melting point is moulded over the PU so it has enough heat to fuse to it.
Pat
for site rules
