Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I've gotten solutions within a day - it saved a lot of time and actually got me one ATTABOY from my boss..."
Geography
Heat transfer from hot liquid, through wall to cold liquid below.Helpful Member!
Mariusz001 (Marine/Ocean)
31 Mar 12 5:38
Could anyone help with following, I'm calculating total heat flux from liquid heated by heaters to exterior. Walls of the tank containing heated liquid are surrounded by air, only bottom wall is connected to another tank containing constant (lower) temperature liquid. I've calculated heat transfer coefficients (h) for top and vertical walls using known correlations for natural convection. The problem is that, I'm not sure, how should I treat bottom wall. Should I treat the heat transfer from heaters to lower temperature liquid as a conduction? Through layer of fluid and bottom wall?
Kind regards,
Mariusz
TD2K (Chemical)
31 Mar 12 13:57
Heat loss through the floor is a combination of convection and conduction.
You have a convective heat transfer from the hot fluid to the tank floor, conduction through the tank floor plus convective heat transfer to the cold liquid.  Fouling, if there is any, would be another factor on one or both sides of the tank wall.
31 Mar 12 14:17
Convective heat transfer is a mechanism of transporting energy with movement of fluid. In terms of natural convection movement of fluid occurs with density differences. In this case, the floor is colder than above fluid. So the fluid closer the bottom is denser! So what convection are You talkin about?
Helpful Member!  Compositepro (Chemical)
31 Mar 12 16:06
Heat flow downwards will be by conduction only, not convection. There will be a short distance below the heaters where there will be some effects caused by turbulence effects due to natural convection. A shroud around the heaters that extends to the bottom can create convection to the bottom.
31 Mar 12 16:20
Compositepro, thanks. That's just what I've suspected.
rmw (Mechanical)
31 Mar 12 17:53
I read a statement in a Heat Transfer text book once that stated "it is considered that if Re is <2000, no heat transfer takes place.  Take your liquid properties and see how much velocity would be required to get Re above 2000 and ask yourself if you think you have that type of movement in the tank(s).
rmw
IRstuff (Aerospace)
31 Mar 12 19:58
That seems to be counterintuitive.  If Re is low, say 0, then there's still conduction.
TTFN
rmw (Mechanical)
31 Mar 12 21:34
Well, Re refers to fluid flow so I thought I didn't have to state that the quote referred to convection heat transfer.  Yes, you would be correct - there is always conduction.
rmw
IRstuff (Aerospace)
1 Apr 12 0:10
Close Box
Join Eng-Tips® Today!
Join Us             Close
