Remove color to a body or faces
when I create an extrusion, that is a body, I can change the color of the body, from gray to blue using 'Edit object display' command.
I can do the same for faces.
But how can I remove color faces customization, so they return to the body color ?
I know that I can inherit from other faces, but doing this procedure I will not be able to select the body and change the color without enable 'Applay to all faces' setting.
In other words, How can remove any color faces customization ?
The same question in assembly.
Some colleagues has changed color to components with the solid body filter enabled and I'm not able to reset the color to the component color.
Thank you...
Using NX 8 and TC8.3
RE: Remove color to a body or faces
Note that you have to be careful as the next time you open the 'Edit Object Display' dialog that 'Apply to All Faces of Selected Body' option will still be toggled ON so you may want to toggle it OFF before you proceed with another edit.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
sorry for the delay, but I'm testing NX 8 and NX 8.5 for the future switch in our company.
I've seen that NX 7 has a bug respect to NX 8, for this I open this topic.
If I was using NX 8, this strange behavior I didn't found.
Thank you...
Why do you have to be a nonconformist like everybody else?
- James Thurber
