casting model won't blend..Mapping error?
I am working on turning a machined part into a casting NX7.5, I have not done any casting parts in about ten years. I have ONE troublesome edge that will not take an edge blend. I believe I know the cause, probably a sketch where an arc and a line meet to make a bit of a point instead of a smooth transition. I am trying to edit the sketch to smooth out that transition but I get a mapping window which I do not understand what it wants from me, I searched help and could not find an example. I am not pleased with the model as a whole. I am under the gun to get this out to the shop for a model or I would start from scratch..all i need is one place smoothed out and I am on my second day of wrestling this one edge..:( Can anyone explain this edit sketch mapping dialog?
RE: casting model won't blend..Mapping error?
