"fly mode"
"fly mode"
I don't really know how else to describe this, but is there a way to "fly" in your part/assembly rather then rotating&zooming it?
NX 7.5
Teamcenter 8
RE: "fly mode"
Best regards
Simon NX7.5.4.4 MP5 - TC 8 www.jcb.com
RE: "fly mode"
Or if you push CTRL+H it will open up the section view menu, with a lot of options to play with.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit
RE: "fly mode"
Micky, see thru is fine if the assemblies aren't too big. Section view was what I used atm. I was looking for something better.
NX 7.5
Teamcenter 8
RE: "fly mode"
Ctrl+Shift+MB1 (drag upwards ="increase perspective") - You need perspective to be able to fly past objects.
MB1 (slow) left/ right = turn left/right
MB1 up/down = fly in/out
Shift+MB1 = up/down = Fly-turn up/down
Shift+MB1 = right/left = roll (rotate about screen z)
Ctrl+MB1 up/down/right/left = ("pan") fly sideways
Under View Navigate Options you can set the sensitivity, the flight might be too high speed per default.
RE: "fly mode"
NX 7.5
Teamcenter 8
